by James_Minety Investigator
WARNING - You can be charged for data even though roaming turned off
I have just returned from New Zealand, I turned off roaming but had the EE Travel Pass switched on in case of emergencies, but with roaming off I thought no charges would be incurred. It seems that mobile data can be triggerred in the background unless you also turn the mobile data switch off. Checking the settings on the phone I can see that mobile data was used during the 4 weeks I was away, although in total only 100Mb was used but this triggerred 26 daily travel pass charges at £6 each!.
If you don't need mobile data and will only use WiFi I suggest you ensure mobile data is turned off as well as roaming and cancel the Travel Pass before you go.
Hope this helps
Re: im abroad and switched my data roaming off but not mobile data wil i be char
Bad news I'm afraid at least if you also have a Nokia 6.
Hope this helps
@James_Minety   Unless time travel is possible I don’t think your post will help as this was posted in 2016.
Thanks Chris.
Perhaps I should have created a new posting.
Just wanted to alert other users of the Travel Pack and Nokia 6 phone.
Regards
@James_Minety : I've done it for you.
I'm sure I saw other posts under your nick or close to it yesterday, but can't find them now.
