by edvbevan Contributor
Voicemail notification abroad
I keep getting a voicemail notification on my android phone. I live abroad, so would like to access it without paying too much in roaming costs. Is there a way to get messages overseas online?
by Brilliant Contributor
Solution
Re: Voicemail notification abroad
Hello @edvbevan,
Welcome to the community,
Sorry, no there is no way to get a messsage overseas online, the only way to listened to your voicemail is via your phone, or using another phone, but in both cases you need a pin to access your voicemail.
Solution
Hello @edvbevan,
Hi @edvbevan,
Welcome to the EE Community.
That's a great answer from @Schockwave.
Please take a look at our voicemail guide if you would like to find out more.
