by therockisnow
Voicemail Access ...
hi there
i am trying to access my uk voicemail whilst abroad. that means to say i am calling from a a foreign number to the ee uk voicemail service ... 07953 222 222
however the message keeps repeating "enter your full mobile number followed by the hash key" ... i make the appropriate actions, however the system does not register anything and keep looping the message.
any ideas?
13 REPLIES 13
Re: Voicemail Access ...
@therockisnow  Did you set up a PIN number to access your voicemail?  As you need to do this when using a non EE line or if your using your device from abroad.
by therockisnow
sure thing.
i have got the pin number as i access it from other uk phones as well.
this is why it is so puzzling ...
thanks in advance
EE Employee
Hi @therockisnow and welcome to the community.
So I can try to help, please may I know what type of phone you have.
Many thanks,
Lee
by therockisnow
hi there
thanks for the reply
the ee sim card is in an old phone
i am trying to access the voicemail dialing from an iphone
thanks
EE Employee
Hi @therockisnow
Is the iPhone on EE or another network?
Many thanks,
Lee
by therockisnow
iPhone accessing it is not in ee
But that’s not an issue... I have got through before on it.
For some reason now - it’s not working. The message keeps repeating and doesn’t recognise the numbers that I enter ...
EE Employee
Hi @therockisnow
Are you able to access any menu driven type calls?
It could be an issue with the DTMF tones on the network you are currently using.
Many thanks,
Lee
by therockisnow
Ah ok.
How do you suggest that I can test the feature ?
EE Employee
@therockisnow
Which network are you using?
Many thanks,
Lee
by therockisnow
i am abroad at the moment...
EE Employee
Hi @therockisnow
Are you able to test another number that requires touch tone menu options.
Many thanks,
Lee
by therockisnow
Hi there
I did try another number that requires the dial on the keypad on the phone. A different network provider voicemail !
It worked fine ... !
For some reason ee does not recognise this ...
EE Employee
Hi @therockisnow
Are you able to try any other phones to see if it is a specific network issue.
Many thanks,
Lee
