by Marcuse73
New Member
Using phone internationally
Is Canada covered under business tariff
Solution
Re: Using phone internationally
@Marcuse73: It's included under EE's Max Plans. I dunno if you have those on business plans.
If you don't have a Max plan you might be able to add roaming in 5 extra countries, incl. Canada, by texting GO FURTHER to 150 @ £10 / month for a min. 6 months. See Go Further Roaming Add-on .
Solution
Hi @marcruse73
Welcome to the community. 🙂
I see @XRaySpeX has given you a brilliant answer here.
Don't forget to make sure your phone is set up for roaming before you go.
You can check in your My EE account or by texting ROAMING to 150.
Have a great trip.
Chris 🙂
Recent solutions
