by jacqueline0 Valued Contributor
Valued Contributor
Using phone in USA
When  in USA can I call USA numbers on new max plan
Solution
Re: Using phone in USA
@jacqueline0: Yes. Make sure roaming is activated on your a/c before you leave by texting ROAMING to 150.
Solution
Valued Contributor
So will a US number be able to call me on the max plan
What the US no. is charged calling you, a UK no., will depend their plan & network. They will be charged at their network's International calls rates. It has nowt to do with your plan.
EE Employee
Hi @jacqueline0 and welcome to the community.
Just to add, on the max plan your incoming calls in the US would be included and not charged extra 🙂
Enjoy your trip.
Many thanks,
Lee
Valued Contributor
Thank you so much
