by edhammond82 Contributor
Using my phone on In america after 10th May 2017
Im going to the USA in September and was wondering about romaing.
Ive found the artical below which explans that on my EE4G Max plan i would be able to use my data allowance in the States at no extra cost. Is my understanding of this correct? Do i have to register for something or is this offer only for new customers?
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-customers-after-10th-ma...
Solution
Re: Using my phone on In america after 10th May 2017
Hello there @edhammond82.
Thanks for coming here.
If you have a new 4GEE Max Plan that started from the 10th May you can use your allowance in the USA.
If you have had your plan before the 10th May you would not have the USA included in your allowance.
If you wish to change your plan to a new 4GEE Max Plan please give us a call 🙂
Thanks very much!
Solution
Thanks very much!
by Ace Contributor
The Travel Data Pass may be an option for you as well. £4 a day for 500MB of data.
http://shop.ee.co.uk/international/travelling-abroad/travel-data-pass
