by Brj1977
Using my phone in Tenerife
Is Tenerife included in eu roaming
Solution
Re: Using my phone in Tenerife
Yes, it is part of EU. You may use your usual allowances there with up to 15 GB data per billing month if you have more.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
Solution
