Highlighted
New Member
Using my phone in Mexico
Hi I am on the Ee max plan and I was wondering if anyone know if I can you my data texts and minutes in Cancun
Highlighted
Solution
Re: Using my phone in Mexico
@Laura401  On a max plan providing you took it out after the 10th may 2017 you can use your allowances in Mexico.  Just text ROAMING to 150 before you leave the UK.  You can do this now if you wish so your all set for when you do go.
Highlighted
Solution
Recent solutions
