by JBow
Using my phone in China
Going to Shanghai. What is the best way to make sure I can still use my phone while in china.
Solution
Re: Using my phone in China
@JBow  Have a read of THIS .  You also need to make sure roaming is enabled on your account before you leave the UK, to do this you just need to text ROAMING to 150.
Solution
by JBow
Thanks, appreciate it!
