by Channi1990
Using mobile in NYC
Hi! We are visiting NYC early next year and both have max plans with EE. What do we need to do if anything to get our phones ready to use while there. Probably won't be using much just odd calls and texts to touch base with people back home. Just don't want to be charged over the odds.
Thanks in advance
Solution
Re: Using mobile in NYC
Just remember to text ROAMING to 150 before you leave UK to check roaming is enabled on your account.
Solution
