by Tom5 Contributor
Using mobile data in Cyprus is practically unusable and no 4G is available
7 REPLIES 7
Re: Using mobile data in Cyprus is practically unusable and no 4G is available
Hi @Tom5
Where abouts are you?
EE are not responsible for foreign mobile networks or the quality of the signal you may receive.
by Tom5 Contributor
The south near Paphos
by Scholarly Contributor
You should get 4G using MTN.
by Tom5 Contributor
My phone at the top says 'Cyta-Voda' and when I try manually connecting to MTN I get no service and using the 3G network is very slow
Good Morning @Tom5.
Is there any other networks available when you try to manually search?
Do you know of any other users having the same issue?
Jon
by Tom5 Contributor
The issue has fixed itself. My phone now connects to MTN 4G and runs at 30MBPS. Thank you for your help.
Great news @Tom5!
Thanks for the update. Smiley Happy
