by Andelou Investigator
Using data allowance in Greece
I'm confused. Can I use my 10GB data allowance in Greece or do I need to buy the £4/day add on?
Re: Using data allowance in Greece
You may use all your UK allowances in Greece, but you must make sure roaming is enabled on your account. Text ROAMING to 150 before you leave to check it is.
Hi @Andelou
Welcome to the community, it's lovely to have you on board. 🙂
@XRaySpeX is absolutely correct.
Just to add a little more, check out our Free EU roaming: Who’s covered and what’s included supporting article.
You can also find out any chargeable services (not calls, texts and data) on our roaming tool >
Have an amazing time in Greece. 😄
Thank you for those replies. I have roaming available on my phone (I texted 150 as advised). Do I need to do anything in settings when we arrive in Greece? I.e enable data roaming?!!
thanks again
You're welcome, @Andelou.
Yes, make sure data roaming is enabled and also that your carrier is set to automatic:-
Tap Settings >>> Tap Carrier >>> Make sure that Automatic is enabled.
This will mean that your phone will automatically connect to the first available Greek network when you arrive.
Have a lovely trip. 😄
  • Thanks chris, much appreciated!!! Xx
