by sheeshon Contributor
Using Pay As You Go abroad
I have a PAYG phone. I'm going to Canary Islands in July. Do I need to buy add ons to use data, texting or calls.
Last year the guy in the EE shop said no, it just comes out of your credit. Ended up being unable to use my phone for 2 weeks. Don't want the same to happen again.
by Ace Contributor
Solution
Re: Using Pay As You Go abroad
@sheeshon
If you have pay as you go Pack then you can use your allowance in Europe with out any extra cost after 15 June.
Many Thanks
by Ace Contributor
Solution
@sheeshon
Many Thanks
Thank you.
EE Employee
Hi @sheeshon
Hope the information supplied by @Chris_B and @tahirmian was helpful.
Many thanks,
Lee
