by Chaudh28 Contributor
Using EE IN AUSTRALIA COST
I am currently on  EE 4g max plan and want to know how much it will cost if i use my current package in australia?
Solution
Re: Using EE IN AUSTRALIA COST
Hi @Chaudh28
If you added your Max plan on or after 10 May 2017, you'll be able to use your normal UK allowances when travelling Down Under. 🙂
That's calls, texts and data, although the data is limited to 15GB.
Have a fantastic trip!
Chris 🙂
Solution
Hi @Chaudh28
Chris 🙂
