Highlighted
by Investigator
Usa usage on max plan
Im going to the usa next week and am on 4g max plan started nov 2017. Do my allowances count in america and are they free or chargeable please? Or is it better to turn data off and use wifi?
10 REPLIES 10
Highlighted
by Ace Contributor
Re: Usa usage on max plan
Hi @Jenny3031
Welcome to the EE Community,
Yes you can use your mins texts & 15GB of data in America.
Highlighted
by Investigator
Is this at no extra cost please?
Highlighted
by Ace Contributor
@Jenny3031 yeah they are included in your tariff at no extra cost.
Picture messages are chargeable.
Highlighted
by Investigator
Thank you for your help, one last question, do you know if calls and texts to me from the uk whilst im in usa will be charged to me or people calling/texting me thanks.
Highlighted
by Ace Contributor
@Jenny3031 When people call or text you from the UK they will be charged for calling or texting a UK number
Your incoming calls & texts are also free.
Highlighted
by Investigator
Thank you x
Highlighted
by Ace Contributor
@Jenny3031 your welcome 😊
Highlighted
@Jenny3031
Please ensure you text ROAMING to 150 to ensure the service is set up on your account. If not you can log into your online account and activate roaming and international calls.
Highlighted
by Ace Contributor
@Jenny3031
to ensure roaming is set up on your account check the following.
log into your My EE account online.
go to Menu > Manage Device > Roaming and also Call Abroad and Premium Rate > They will need to show as ticked for you to use your phone abroad.
If you can activate both settings this will update within 24 hours.
If the options are greyed out you will need to contact 150 to activate it.
Highlighted
by Scholarly Contributor
Just to let you know the Fair Usage Policy of 15GB doesn't apply in the USA so you can use all of your allowance there if you want!
Recent solutions
