by redjess14
Unlimited EU SMS won't work
Hi. I am in Ireland using a UK mobile on EE. I have limited EU and UK calls and can successfully call back to the UK or to my partner on his Irish number. I can also text the UK with my Unlimited UK texts. However, whenever I try to text my partner on his Irish number the texts won't deliver and I get a 'Message Send Failure' alert. I have Unlimited EU SMS so I don't see why this is? I have ensured I am using the correct +353 code for Ireland.
We both have iPhones, but I have tried turning iMessage off and selecting 'Send as SMS' in the settings but still nothing will send.
Any help would be appreciated!
Thanks,
Jessica
by Ace Contributor
Re: Unlimited EU SMS won't work
@redjess14
Try with 00353 check it might work.
Many Thanks
by redjess14
Hi, thanks but it still won't work Smiley Frustrated
by Ace Contributor
Try manually search network.
Then turn off your mobile and turn back again.
Check again.
Cheers
EE Employee
Hi @redjess14
Can you receive texts from the number OK?
When you do the manual search try choosing an alternative network.
Thanks - Karen. Smiley Happy
