by avagrahblupiv
Understanding data roaming add on
I just got to China and bought 500mb of data roaming for GBP 6. It should last for a day but says valid for 6 hours. Any idea why? Also is it 24 hours from when you buy or works on 24 hour clock?
Solution
Re: Understanding data roaming add on
Hi @avagrahblupiv
It's 24 hours UK time
Your data allowance will be available for you to use until midnight,
UK time, each day. If you use your allowance of data before the end
of a day and still want more data, you can buy another pass. It may
take up to 24 hours to be applied to your account from the moment
you opt in and you’ll receive a text message to confirm when it has
been added.
Solution
Hi @avagrahblupiv
been added.
Recent solutions
