by Kerrygipp Investigator
Unable to use phone abroad
Was able to use.phone abroad how not cant call 360 or 150 help as I need my phone!
Re: Unable to use phone abroad
Hi @Kerrygipp.
Welcome to the community.
Does your phone have a signal?
Where are you currently roaming?
What phone are you using?
Jon
If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
Hi, no signal, did have roaming on, now nothing
Thanks rebboting still not worked
Thanks for trying @Kerrygipp
Could you try manually connecting to a different network?
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Settings > Mobile Network > Network Selection > Tap on start manual search
