by saj1994 Investigator
Unable to make calls, send texts or use data from canada.
Im in Canada at the moment and unable to make any calls, send texts or use data. I cant even reply back messages received from EE.
I have an iPhone 10.
16 REPLIES 16
Re: Unable to make calls, send texts or use data from canada.
@saj1994   Did you enable roaming on your account before you left the UK ?     Do you have a signal showing on the device?   What tariff do you have ?  And have you enabled call abroad and premium rate numbers from within your online account?
No I did not enable roaming, yes there is a signal and the network is connected to rogers, im on pay as you go and I topped up and bought a bundle.
how do i enable call abroad and premium numbers online?
@saj1994   With PAYG you don’t need to activate roaming as it already is.   You do however need credit to pay for calls/text and a data bundle to use data as your PAYG pack will not work outside the U.K./EU.
@Chris_B  I have topped up and have a balance.
@saj1994   Have you tried restarting the device since topping up ?
yes I have
@saj1994
You have said you purchased a bundle this is not credit on your account.  You can not use packs outside the UK/EU. You need to top-up and use that credit to pay for everything.
I have got a bundle and got credit of £2 left on the account.
Hi there @saj1994
Thanks for coming here.
What happens when you try and make a call or send a text?
Have you used the SIM in the UK before you travelled to Canada?
Leanne 🙂
Forget the bundle! It's no use in Canada. You have only £2 to spend on calls & texts, which is enough for 1 min of calls or 3 texts. You can't use data as you've not enough to buy a data add-on. For charges there see https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/canada .
Yes I know i can use the credit to send texts but the texts that I am sending is not going through
@saj1994   Are you putting 44 or +44 instead of the 0 at the start of the number?
Hi @saj1994
Thanks for coming back to us.
Can you try and select a different network in the settings?
Go to, Settings > Mobile Data > Network Selection > Turn off Automatic
@Leanne_T When I try send message I get an error saying not delivered.
i tried changing to other networks but still same problem.
Hi @saj1994
Thanks for coming back to me.
Can you make any calls?
Is this to more than one number?
