by mw07london Investigator
Unable to.call UK from USA. Roaming enabled and add on purchased?
Every time i try to ring a contact in the phone or dial a number in the uk, i get the same recorded message from t-mobile saying that " the service you are attempting to use is restricted or unavailable  contact customer care with message FL14365". Roaming is enabled and I have purchased the appropriate add on.  Please help!!
7 REPLIES 7
by Brilliant Contributor
Re: Unable to.call UK from USA. Roaming enabled and add on purchased?
Hello @mw07london,
Welcome to the community,
Have you made sure that you have international dialling enabled?
You may want to check here about roaming if you have not already done so:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-What-to-do-if-you-re-having-problems-abroad/td-p/66...
Hi @mw07london,
Welcome to the EE Community.
That's great advice from @Schockwave. To remove the international calling bar, please login to My EE and select 'Manage device' from the menu.
International dialling is enabled and I have roaming plan confirmed - still not working ...!
Roaming is enabled where? You may have it enabled on your phone but did you enable it on your EE a/c before you left by texting ROAMING to 150?
Are you able to use data to get on the Net?
Unfortunately yes - have texted 150 and have received a reply that roaming is already enabled. Am able to access data with no problem but just can't call anywhere.
If "anywhere" Is non-UK nos, you need "Call Abroad & Premium Rate" allowed in your MyEE. If you can't tick it yourself you will need to ask EE. Use the landline nos in my sig from another phone.
Hello there @mw07london
Thanks for coming back to us.
Has the advice from @XRaySpeX helped you make calls?
Speak soon, Leanne.
