by Pagemakers Established Contributor
Unable to add a Travel Pass
I’m on a 12M SIM Max Plan
When I send a text to 150 with the words MAX TRAVEL it replies with:
Sorry, Travel Data Pass is not available on your price plan. You can find details of all our standard roaming add-ons and prices at ee.co.uk/roaming
Why can’t I add a travel data pass to my account. I should be able to.
41 REPLIES 41
by Ace Contributor
Re: Unable to add a Travel Pass
Hi @Pagemakers. Have you tried just texting TRAVEL Instead?
Yes - makes no difference. Exactly the same response.
Good Morning @Pagemakers
Are you currently outside the UK at the moment?
What destination are you looking to use the pass?
Katie 🙂
I’m in the UK at the moment. I travel on a weekly basis so it could be anywhere.
Last week it was Turkey.
Thank you for confirming this. @Pagemakers
I would recommend speaking with our customer service team who can have a look at your account.
Keep me posted on how you get on 🙂
Katie.
I have. Three times in the last 2 days. They just scratch their heads and nothing changes.
I have sent you a private message @Pagemakers
If you could take a look and get back to me 🙂
Katie.
by Ace Contributor
Have you managed to get through to someone in technical support? They are usually more competent and willing to look at issues that take a bit longer.
PM replied to.
EE have called me twice this week and I’ve called them once. Not sure which department they were from.
This is the issue...
Another week and 3 more phone calls and both phone numbers on my account still have this bug. How much longer?
by Ace Contributor
Hi @Pagemakers Sorry to hear this isn't fixed. If it was me, I'd start escalating the issue. Raise a complaint, ask for it to be passed to the next level of support, Keep a track of who you talk to and when, and what was said. You need to keep on top of it but once you start following EE's complaint process they do tend to get picked up by more competent staff who take the time to try and resolve issues.
Let us know how it goes!
I’ll give that a go. Thanks.
Two more long calls with EE and still this doesn’t work. That must be 10-15 calls so far.
Regrettably looks like I will have to go down the complaints route.
I'm sorry to hear that, @Pagemakers.
Did you ask to raise a complaint whilst speaking to customer services?
You can find other ways to do this on our raise a complaint help page.
I raised a complaint using the online complaint form.
by timmylad1975
Hi, try and Text MAXTRAVEL to 150
Think thats how i got mine to work
That’s  the whole porpose of this thread.
Texting that to 150 does not work at all. There are photographs above.
MAXTRAVEL
MAX TRAVEL
TRAVEL
Does not work. They all should.
