by jcrawford
Unable to Roam
unable to roam with roaming enable on my airtime plan and device correctly configured. Randomly stopped working?
Any Ideas?
Solution
Re: Unable to Roam
Where are you?
If on contract, did you activate roaming on your EE a/c before you left UK?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your My EE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
Solution
Re: Unable to Roam
Where are you?
Re: Unable to Roam
Hi there @jcrawford
Have you been able to follow the advice from @XRaySpeX?
Is this now resolved?
Speak soon,
Katie 🙂
