by Lucy20x
New Member
USA
I’ve just moved to the USA but I am still paying for my monthly contract for the UK I was wondering if there’s any way I can swap to be able to use this in the USA?
Re: USA
@Lucy20x   At best you could use this for 2 months if you change to a max plan after 2 months then you’ll be paying for international calls/texts.   Your best option is to pay off the contract as you get a 20% reduction on the cost compared to paying of the contract until them minimum term date.  UK contracts are not meant for long stays abroad.
