by Dorsica
USA
can I use my data in the USA and how much would it cost me?
Thank you
by Ace Contributor
Re: USA
Hi @Dorsica
You can find all the costs for roaming here.
The Travel Data Pass is £4.80 a day for 500MB data.
Ensure you have roaming enabled on yhour account before you leave, text ROAMING to 150 now to check.
Re: USA
Hi @Dorsica,
Welcome to the EE Community.
Which plan are you using?
