by nikkih1
New Member
USA Roaming
Hi, I am travelling to the USA soon. I am on  MAX plan with 100GB of data, unlimited calls/texts. Will the following be included in my allowance whilst I am in the USA?
- calls/texts to USA numbers
- calls/texts to UK numbers
- phone data usage such as google maps & general internet use.
I think i have read that it is included however i would like a definitive answer, just in case!!
Regards, Nikki
Solution
Re: USA Roaming
Hello there @nikkih1
If you have a Max Plan started after 10 May 2017, you can also use your minutes, texts and up to 15GB of data within America 🙂
Before you go, check your roaming is set up by logging into your My EE account online go to Menu > Manage Device > Roaming Abroad and also Call Abroad and Premium rate> They will show as ticked if roaming and calling abroad is activated.
If you can activate these settings, you will be able to use your phone abroad 🙂
Have an amazing time!
Re: USA Roaming
Yes but EE limits roaming data to 15 GB per billing month.
Solution
Re: USA Roaming
