by Pagemakers Established Contributor
USA Roaming Partners
Who are EE’s USA roaming partners?
The only network I can connect to is T-Mobile.
I’d like to connect to AT&T but it doesn’t seem to connect at all.
14 REPLIES 14
Re: USA Roaming Partners
@Pagemakers   EE use T-Mobile and AT&T but depending on your location you might not be able to get onto the AT&T network.
Ah OK. I’m in Orlando. I see the AT&T network but when I connect to it, it says no service. I know there is service here because my mates on THREE roam on it.
Any idea why you can’t use AT&T nationally?
Do you know where AT&T works in the USA?
EE Employee
Hi @Pagemakers and welcome to the community.
Your device will pick the best available network for you when it can, is there any reason you are wanting to use an alternative network?
Many thanks,
Lee
I want to use AT&T because it has better coverage than T Mobile
It appears when I manually search but when I connect it it it says No Service.
I thought AT&T were a USA partner.
When I was with THREE it defaulted to T Mobile but I could freely roam on AT&T
by Profile closed
Not applicable
I also found AT&T didn't work when I was in Chicago the other week.  AT&T did work in New York though, well at JFK airport anyway.
I did ask EE about it but no-one got back to me.
I even got this at one point:
No idea what was going on with that, but it was whilst I was at JFK Airport?
EE Employee
Hi @Pagemakers
We do use various partners when roaming.
I will certainly try and look into this further.
Many thanks,
Lee
Thanks Lee
Mitchel - that is an iOS 11 bug. Looks like it’s been fixed now.
How weird. Now I’m at Orlando Airport AT&T is working. It wasn’t yesterday!
Hi @Pagemakers
Thank you for coming to update us 🙂
Really pleased that you have network, are you getting into Orlando or leaving?
Richard
I was leaving. I was there for 3 days and I could not log onto AT&T at all while I was there. However it did work as I was leaving from the airport.
Should I be able to connect to AT&T at all times in the USA?  I’m there often.
Hi @Pagemakers
I will tag in @Profile closed here if he can support with this please.
Cheers
Richard
by Ace Contributor
It will also depend what phone you have. This is a helpful site:
https://willmyphonework.net/
Sorry. That’s irrelevant here. I have an iPhone 7+ and that has nothing to do with AT&T as an EE USA roaming partner.
