by MickyK
UK & EU data add-on - where did it disappear?
I live in Israel and often visit UK and Europe.
I use a prepaid data card and always before visiting buy a data add-on.
Previously when visiting the UK I bought an UK data add-on, and for the EU countries - an UK & EU data add-on. The latter used to work also in several non-EU countries, like Switzerland.
But a month ago or so it disappeared. Now the add-ons proposed vary by data amount and price, just as previously, with the only exception - there is no UK & EU data add-on.
Does that mean that all these add-ons will be valid in EU countries, as well as in the UK?
Or, on the contrary, they are solely for the UK?
Thank you a lot.
Solution
Re: UK & EU data add-on - where did it disappear?
@MickyK   You can use the same allowance that’s used in the UK for the EU now so you don’t need to purchase any add ons.
Solution
by MickyK
Thank you a lot
