by base82 Investigator
Turn on roaming
Hi I am on holiday adroad France my harrier phone on we payasugo worked fine for 2weeks now I have no service no network I think I should have asked firm roaming to be switched on by 150 can you please help to have it switch on by we tks
9 REPLIES 9
Re: Turn on roaming
@base82: Roaming is activated on PAYG anyway. If it's stopped working you will need to contact CS.
Do you have credit or allowance to make calls?
Re: Turn on roaming
Hello there @base82
Thanks for coming here,
Can you try and connect to an alternative network in the device settings?
Speak soon 🙂
Re: Turn on roaming
hello,  I have tried to conect to various networks here in france orange free etc
all worked fine until 3 days ago for two weeks whilst i am on holiday.
i had my harrier phone unlocked just before i left the uk 17 Aug.
If I put the simm into an old nokia phone it will conect to any network here
so i thinks it is something to do with the harrier phone and international roaming.i have check the setting on the harrier to make sure call baring for international is un checked and roaming is clicked on  and even did a facory re set several soft re sets .
your help would be appricated with this one.
Regards
base82
Re: Turn on roaming
Hello there @base82
If the SIM card is working fine this will be the device.
Are you able to contact us from the other device so we can get this looked into?
This will need our technical support team for further investigation.
Thanks, Leanne.
Re: Turn on roaming
I never had a response to my roaming problem .
If I switch off the phone for several hours then
turn it back on I can register on a local network but this only last a few minutes.
I think it  roaming needs to be aurthoised by EE customer support.
I am stuck with a EE phone that still does not conncet.
Not a haappy customer
Re: Turn on roaming
Hello there @base82
I have replied to you in this post as below,
Thanks, Leanne.
Re: Turn on roaming
Hi Leanne yes I agree I think its something to do with my Ee Harriet phone .As I stated it was unlocked on Aug 17 via unlock code all worked perfectly in the UK and here in France for two weeks then cannot connect to networks if I put the sim in an old unlocked Nokia it finds the network straight away which leads me to suspect there is a configuration setting for this Ee harrier phone at your end that may resolve this issue your help in resolving this would be greatly appreciated.I can on you my account details and I me I if this helps tks Brian
XsRe: Turn on roaming
pa if I switch the Harris phone off for several hours then back on with the Ee sim in it it will connect to a network but only for  a shirt time till the server disconnects it again.tks
Re: XsRe: Turn on roaming
Hello there @base82
Thanks for coming back to me.
I am sorry we have no account access to look into this for you.
If you can give us a call the team will find out what could be causing this.
Thanks, Leanne.
