by GraemeSmiffy
New Member
Turkey roaming charges
Is there a way to reduce roaming charges when in Turkey.
For local calls as well ?
Solution
Re: Turkey roaming charges
Hi @GraemeSmiffy
You can buy an add-on. You can see which add-ons are available on the Turkey roaming page:
https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/turkey...
Solution
Hi @GraemeSmiffy
