by Sanjhussain Investigator
Travelling to the USA on a max plan do I turn roaming on still
I'm going away to the USA I'm on a max plan which includes USA do I still need to turn my roaming on my phone so I can use my minutes/ data etc
15 REPLIES 15
by Profile closed
Not applicable
Re: Travelling to the USA on a max plan do I turn roaming on still
Hello @Sanjhussain yes roaming still needs to be enabled on MAX plans if you have not already done so:
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-using-your-phone-abroad
Text ROAMING to 150 and it will tell you if this is active or not.
Thanks,
Not just on your phone but on your MyEE a/c also.
Hello there @Sanjhussain.
Thanks for posting on the community.
Please do follow the great advice and make sure you are all set up.
Hope you have an amazing time 🙂
Going to NYC on a new max4G plan my roaming is readyTo use. what more do I need
Going away on the new max 4G plan what do I need to do?? My roaming is set
Re: Going to NYC on a new max4G plan my roaming is readyTo use. what more do I n
Is roaming activated on your a/c, not just on your phone? Text ROAMING to 150 to check.
Hi yep I text roaming to 150 they sent a mesh back telling me my phones all ready
Says all I need to do when I get there is turn phone off & back on again.
Do i still
need to turn my roaming on on my
phone??
Yes, but that's under your own control unlike getting it activated on your a/c.
Thank you everyone much appreciated
Hi ya
thank u :smileyhappy Smiley Happy
I will definitely follow all ur advice
Have an amazing time in the USA @Sanjhussain
Richard
by Ace Contributor
You could check your phone will work out in the USA on T-Mobile or ATT.
https://willmyphonework.net/
Hi @Sanjhussain
I can see you have been getting advice here as well.
Richard
