by gregbjefferis
Travelling to UK from Canada...09-03-2019 to 10-03-2019...sim only plan avail?
Re: Travelling to UK from Canada...09-03-2019 to 10-03-2019...sim only plan avai
@gregbjefferis : Is that for 1 month in Americanese? Suppose it must be!
What do you want it for? UK calls & text + data? Calls & texts back to Canada? How many/much?
Buy a PAYG SIM on arrival at airport. As soon as you get it text CALL ABROAD to 150 for a free add-on giving much cheaper than standard rates for calls (3p / min Canada & USA) & texts (10p each Canada & USA) to abroad.
by gregbjefferis
Hi.thanks for the response (i.e. from Canada.a Canuck not a Yank!!).and yes
it is a month.
Looking for some local UK calling and texts, plus a reasonable amount of
data for 50 GBP or less for the month.
Helpful tip.thanks again.
I didn't mean "Yank"; I just meant N. America in general 😁.
Look on SIM Only Plans for the sort of SIM plans available. You have the choice of:
  • 30-day contracts, but you must give EE 30-days notice to stop it.
  • PAYG, use as you will if the quantities are sufficient. Hence why I recommended it.
You won't be able to order from there unless you can name a UK delivery addy.
by Brilliant Contributor
@XRaySpeX for us canadians we class ourselves and canadians from Canada not North America.
OK, stand corrected 🙂 !
