by gerry_chandler
Travel to Eire
Do I need to set up anything prior to travel to enable me to use both cellular voice and data whilst in holiday? Thanks. Gerry
Solution
Re: Travel to Eire
Good morning @gerry_chandler
Fantastic advice from @Profile closed
Just to add a little, we recently made some changes to roaming in the EU.
All our 4GEE Essential plans, 4GEE plans and 4GEE Max plans will let you take your allowances with you to the EU.
You can see more information on our What EU roaming changes mean help and support page.
Have a brilliant holiday 🙂
by Profile closed
Not applicable
Re: Travel to Eire
Hello @gerry_chandler all EE, T-Mobile and Orange PAYG accounts are set up with roaming already enabled and ready to go. All EE, T-Mobile and Orange PAYM accounts require roaming to be enabled at least 24-48hrs before flying.
Text the code ROAMING to 150 to check and enable roaming if necessary.
Here is a link containing more information on setting up and using your phone abroad:
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-using-your-phone-abroad
Solution
Re: Travel to Eire
by gerry_chandler
Re: Travel to Eire
Thanks Chris! Much appreciated. Gerry
Sent from my iPhone
