by John890
To use data in Spain, do I need to switch Data Roaming on?
Hi I am in Spain and have connected to Orange-EE, and can make calls etc, but cannot  connect to internet/emails etc, should I switch Data Roaming to on in order to get data? Thanks
Solution
Re: To use data in Spain, do I need to switch Data Roaming on?
Yes if you want data you need to activate roaming.
Have you a data allowance to use abroad on your plan as if not you will need to activate but you should have received some txt regarding this when you landed.
Solution
by John890
I do have data allowance included.  I received two text messages from EE, but there was no mention of Data usage.  Am I safe to switch Data Roaming on and not risk a big bill when I get home
If you have EU data allowance on your plan then you will be fine and won't be charged but if not then you will need to buy an add on more details are here.
