by Eship Investigator
Thailand
Hi. Currently in Thailand and brought a cheap payg phone to save costs while over here. I am unable to sent texts or make calls but can receive texts. The message currently says the network is barred as per my request. This is obviously not what I requested as i told the lady in the shop where I bought the phone, I need it for this holiday. I'm now stuck with no communication and limited WiFi.  Can anyone help me to work out how to remove the bar?
9 REPLIES 9
Re: Thailand
How can EE help with a Thai phone? Take it back to the shop where you bought it.
Re: Thailand
Sorry I wasn't clear. I bought the phone in England from an ee shop with a new ee sim card and asked specifically if it can be used I'm thailand and for roaming. The sim worked in Beijing but strangely not in Thailand.
Re: Thailand
EE PAYG SIMs are set up for roaming w/out you having to do anything. Try scanning the networks again for a diff Thai network.
Re: Thailand
I have tried quite a few different networks and all of which have the same problem and same message when I try to ring anyone.
Re: Thailand
Do you have some PAYG credit to pay for calls/texts or some roaming add-on? You do know you can't use your UK Pack abroad?
Re: Thailand
Yes I have plenty of credit.
EE Employee
Re: Thailand
Hi @Eship and welcome to the Community,
So I can try and help, please may I know which device it is that you are using?
Many thanks,
Lee
Re: Thailand
Hi Lee,
I think it is a MobiWire Pictor.
Emma
EE Employee
Re: Thailand
Hi @Eship,
I will have to pass this over to the roaming team to take a look into it as you have mentioned you were able to use in Beijing.
Many thanks,
Lee
