by emz993
New Member
Texting from abroad
Hi my sister is currently on a cruise and can’t connect to the wi-fi so is texting does anyone know the cost and if there’s an add on to try save her some money so it doesn’t cost a fortune thanks
by Profile closed
Not applicable
Solution
Re: Texting from abroad
Roaming charges whilst using cruise ships on-board mobile systems can be found here.
There is no add-on unfortunately to reduce these costs whilst on-board sorry.
by Profile closed
Not applicable
Solution
