by Gweuts Investigator
Texting abroad
I don't understand why I can send texts to Spain and the receiver is getting the text but I cannot receive texts back? Any help would be appreciated, thanks.
10 REPLIES 10
Re: Texting abroad
@Gweuts  if the receiver is on contract they need to log into their online account and enable call abroad and premium rate numbers.
Re: Texting abroad
Hi @Gweuts,
Is the person you are texting on EE?
Are you using standard text messaging or a different messaging app?
Re: Texting abroad
Thanks for your help, will get them to give that a try.
Re: Texting abroad
No they are using a Spanish Vodaphone Sim, I'm using standard text messaging on EE everything pack. Thanks for replying.
Re: Texting abroad
Does the message show as sent from their phone, or is it failing, @Gweuts?
Re: Texting abroad
Hi Christopher, the sender tells me it show as sent.
Re: Texting abroad
How strange, @Gweuts
What kind of phone do you have?
Re: Texting abroad
Its an Alcatel Pixi3....not an Iphone...maybe I need to upgrade!
Re: Texting abroad
Could you check your call bloack settings to see if their number is on the list, @Gweuts?
  • Tap settings and then Call
  • Tap Call Reject
  • Tap Reject calls from
This is where you'll see any blocked numbers
Re: Texting abroad
I have no blocked numbers but thanks for your  help, will try and contact them in some other way.
Many thanks for trying to solve my problem.
