by Monstrum Investigator
Tenerife roaming roaming not working even though account shows roaming enabled.
Hi
I enabled roaming before going to Tenerife and it worked for the first day.  Now I can't use my phone and it says that I'm not registered to use the orange network.
I've tried rebooting and different settings but nothing works.
Anyone four any ideas?
13 REPLIES 13
Re: Tenerife roaming roaming not working even though account shows roaming enabl
Hello there @Monstrum,
Thanks for coming here.
What device are you using?
Are you with us on pay monthly or pay as you go?
Speak soon 🙂
Hi
I'm on a monthly ee personal contract
The phone is a Samsung s7 edge.
Great thanks @Monstrum.
Do any networks show as available in the settings?
Speak soon 🙂
It shows as I'm connected to orange with an r in the signal bar.
Hi @Monstrum
If you go into the device settings and try and select a different network does this work for you?
Thanks.
I have access to orange movistar and vodaphone es, none of them work.
Regards
Hi @Monstrum,
What happens if you try to make a call?
Does your data connection work?
Hi
When I call on movistar it says this option is not available.
When I call on orange it says I'm not authorised.
Data does work on both.
Regards
Steve
Thanks @Monstrum
Can you receive calls?
Just tried on movistar and I can recieve calls. But still can't make
calls.
Steve
There may be an international calling bar on your account @Monstrum
Please login to My EE where you can chat with customer services online.
You should see the option to chat when an agent becomes available.
They'll be happy to check your account settings for you.
Thanks all for your help, I contacted ee via the live chat and it was the
international bar had been partly removed.
Cheers
Steve
Morning @Monstrum,
Thanks for letting us know 🙂
Have a great time!
