by moisei Investigator
TMAX roaming at Scotland and Ireland
Hello,
I've purchased "MTV TRAX Pack" at Southampton and now I am going to travel to Scotland and to Ireland, so I am just worrying will it work there or it will be a kind of roaming?
Solution
Re: TMAX roaming at Scotland and Ireland
The text I mentioned above is free and its just to establish if its activated on your account.
EE roaming guide is here.
What countries are included?
Customers can take their UK allowances to Austria, Azores, Belgium, Bulgaria, Croatia, Cyprus, Czech Republic, Canary Islands, Denmark, Estonia, Finland, France, French Guyana, Germany, Gibraltar, Greece, Guadeloupe, Guernsey, Hungary, Iceland, Ireland, Isle of Man, Italy, Jersey, Latvia, Liechtenstein, Lithuania, Luxembourg, Madeira, Malta, Martinique, Mayotte, Monaco, Netherlands, Norway, Poland, Portugal, Reunion Islands, Romania, San Marino, Saint Martin (French), Saint Barthelemy, Slovakia, Slovenia, Spain, Sweden, Switzerland and Vatican City (Italy).
Customers on a new 4GEE Max plan can take their UK allowances to the above destinations as well as Australia, Canada, Mexico, New Zealand and USA.
Note: Turkey (you may connect to a Turkish network in Northern Cyprus) and Andorra are outside the EU/EEA and not included in our European Roaming Zone.
Ireland is mentioned so you can use your UK allowance as normal.
Thanks,
6 REPLIES 6
You don't need roaming for Scotland as its within the UK.
You may for Ireland so just text ROAMING to 150 and it will tell you if this is set up or not.
Thanks,
Thank you for your answer.
Is there some way to know for sure whether it is a roaming for Ireland or it is not?
I don't want to setup a roaming, I would rather consider different option then.
Solution
Thanks,
Hi @moisei
I see @Northerner has offered you some fantastic help on this.
Let us know if you need anything else.
Enjoy your travels. 🙂
Hi @Christopher_G,
yes, indeed, it was helpfull and I marked the answer as "solution".
Should I close the thread somehow beside of that?
Thank you,
Moisei.
Ah, that's brilliant, @moisei.
Nope, you don't have to do a thing, I just wanted to make sure everything was OK.
I hope to see you around the community again in future.
Chris 🙂
