by borderline Contributor
T-Mobile internet booster
I undertand I can use my t-mobile internet booster in the EU, right?
I just wanted to check with anyone here if it worked fine for them.
It's vital for me to have reliable data on my phone while I'm in Italy
thank you
Solution
Re: T-Mobile internet booster
Not surprised! PAYG SIMs are auto enabled for roaming. No need to text ROAMING. Hence it not doing anything.
Hi @borderline
A quick seach will take you here: https://ee.co.uk/help/add-ons-benefits-and-plans/price-plans-and-costs/t-mobile-price-plans/t-mobile...
And now you can take your Boosters with you, to use anywhere in the EU.
Just make sure roaming is activated on your account.
Thanks,
thank you.
I've been texting to 150 ROAMING to find out if my phone is set up but all I get some text saying I can use 150 code while in UK to check balance and other things but nothing says my account is activated for roaming 😞
Solution
yes thank you. I have also dial 150 and the recorded voice says it's ready to use
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
