by Jeffee
Sweden coverage
What is ee coverage in Sweden?
by Star Contributor
Star Contributor
Re: Sweden coverage
You will most likely use the Telia Sweden network while in Sweden, but roaming partners cannot be guaranteed.
Telia's coverage map can be found here: https://www.telia.se/privat/support/tackningskartor#/tckningskartafrmobiltelefonimobilsurf
I hope you enjoy your trip!
Re: Sweden coverage
Thanks for helping @Peter_C
Hello there @Jeffee
Please also see our getting ready to use your phone abroad post>
This will help you  to make sure you are all set up for Roaming in Sweden.
Have a great time 🙂
