by glenn67
New Member
Stopping charges abroad but need incoming call option...
Hi Everyone,
Newbie here so apologies if i've overlooked something !
I go abroad a fare bit to Asia and i usually take my UK phone and sim and buy a local sim abroad using 2 phones . i rarely use the UK phone BUT require incoming calls as i run a business through it . Consequently , £80 for incoming calls !
So i ask what would the best option for me ? i see EE offer for £10pm  add on and a further £6 for texts while abroad or is there a better option?
TIA,
Glenn.
Re: Stopping charges abroad but need incoming call option...
Hi @glenn67,
Roaming costs and available add-ons vary depending on the country you are visiting.
You can check roaming costs and add-ons here.
Hope this helps.
