by calwoodford Investigator
Still no signal abroad - what can I do?
I'm in Amsterdam and over 72 hours ago I turned mobile data abroad on, it said it would take 24 hours but I still cannot get any service, it just says 'No Signal'. My account is set up to use abroad. Please can you help? 🙂
Solution
Re: Still no signal abroad - what can I do?
Hi @calwoodford
Thanks for coming back to us and trying this.
Can you log into your My EE account online and go to Menu > Manage Device > Roaming Abroad and also Call Abroad and Premium Rate
Do they both show as ticked?
If not, can you turn both settings on within your My EE?
Leanne 🙂
9 REPLIES 9
Hi @calwoodford,
Welcome to the EE Community.
Are you using a pay as you go or pay monthly plan?
Have you tried any of the tips in EE Roaming - What to do if you're having problems abroad?
A pay monthly plan
Thanks for confirming @calwoodford
Have you tried the tips in EE Roaming - What to do if you're having problems abroad?
I've done the manual network search but EE isn't one of the options, only T-mobile NL, NL KPN, vodafone NL and Tele2 NL 😞
Hi @calwoodford,
You won't see EE as an option as you'll need to connect to a local network.
Have you had any success connecting to any of the network options you can see?
No luck connecting to the local networks
Solution
Hi @calwoodford
Leanne 🙂
Ah thank you! 😄 I did change them but it appears they turned back off - strange! Hopefully it’ll work this time
No problem at all @calwoodford
They can take up to 24 hours to activate for you.
Let me know how you get on 🙂
