Highlighted
by Investigator
Sim card
I purchased a 5GB pay as you go sim card in London and was told I would be about to use data and local call/ texts when I went to other countries in the EU. It is day 2 on my sim card and as soon as I left the UK to go to Spain it stopped working. My phone says I am connected to the "orange -Ee" network, roaming is on, but I am not able to use data internet and not able to place calls or texts. Is there something I need to activate or change APNs...etc .? Please help!
6 REPLIES 6
Highlighted
by Investigator
Sim card not working in EU
Highlighted
Re: Sim card
Good Afternoon @Mir123.
Welcome to the EE Community, I hope you're having a lovely time in Spain.
Was your SIM activated and working fine in the UK before you travelled?
What phone are you using?
Speak soon,
Katie 🙂
Highlighted
by Investigator
Re: Sim card
@Katie_B
My sim card was working fine in the UK. It was put into my phone by an EE employee in the store. I have an Android - Pixel 2. I told them in the store that I would be using the sim card in Spain and the employee said it would work fine. Not sure if there was an additional activation required for this.
Thanks!
Highlighted
Re: Sim card
Thanks for confirming this @Mir123.
Did you make a call or text whilst in the UK?
I would recommend trying a manual network selection, you can do this by following these steps:
Settings > More Networks > Mobile Networks > Network Operators > Tap OK.
Speak soon,
Katie
Highlighted
by Investigator
Re: Sim card
Thanks @Katie_B
I did not make a call in the UK but I used data and it worked. Yes, I have manually selected the network but am still not able to access Internet or make local calls. I get a message that roaming is on but that my carrier has disabled my internet. Please advise
Highlighted
Re: Sim card
Hi @Mir123
I have sent you a private message for further information.
Katie 🙂
