by Mitz32
Signal in USA
Can somebody please put on a package so I get signal in the USA plus data. It very hard to get for Uber as I don’t get any signal?
Re: Signal in USA
Hi @Mitz32
What tariff do you have?
If you are on a monthly contract then check roaming is activated.
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Current Usage - Controls - activate use phone abroad and make international and premium calls
Re: Signal in USA
Hi there @Mitz32
Thanks for posting on the community.
Can you follow the steps @Northerner has provided to make sure you are set up for roaming?
You can find roaming charges and add-ons on our EE Roaming costs for USA Help page.
Leanne 🙂
