by AP95 Contributor
Short message transfer rejected
My mobile number switched from Orange to EE about 8 hours ago. I am currently in Germany. I can no longer make any phone calls or texts. Calls are disconnected and all texts to other mobiles and 150 fail and return the message "Short message transfer rejected". I have £5.10 credit and used the mobile recently, so lack of credit or not using the mobile for a long time is not the problem. I was able to open on online EE account and register the mobile and confirm it with a PIN that sent to me, so EE does recognize the mobile number as an EE number.
by Ace Contributor
Re: Short message transfer rejected
I would recommend you give customer service a call, as something seems to have went a miss with the transfer.
You can reach customer service from overseas by calling the following number:
+44 (0) 7953 966 250
HI @AP95
Welcome to the community, I hope you're having a brilliant time in Germany.
Do you know if you're able to receive calls?
Have you tried manually connecting to another available network?
by AP95 Contributor
Thank you for EE's overseas customer services number. Unfortunately, I can make no calls and even calls to EE are disconnected.
by AP95 Contributor
Thank you for your reply.
I do not know if I can receive calls. I have received a text. I tried manually connecting to all three available networks and receive a failure message for all of them.
OK, thanks.
I've sent you a private message to get some more information from you @AP95.
Please have a look and come back to me.
