by TashaSS Investigator
Service in Italy
I’m currently in Italy and can’t get any service. The carrier box in my settings keeps disappearing so somethings wrong I feel.
This has happened before and to make it worse my husband is on EE and can get perfect “WIND” service!
Please advise!
Re: Service in Italy
@TashaSS  Have you tried just restarting the device?   If might be a good idea to give a the SIM card a clean also.
EE Employee
@TashaSS and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
Ive done these twice 😞
The carrier box/option box does not appear, it comes for a second then goes.
EE Employee
Hi @TashaSS
I have sent you a private message on here, so I can get some details from you.
Thanks,
Lee
