by drinu8
Sending ROAMING to 150 does not work
Before going abroad I tried to check whether my phone is setup for roaming by sending ROAMING to 150 as suggested here [EE roaming]. However, when I do so, I get a reply back on my phone as follows;
You can text the following codes to 150 for free while in the UK or EU:
BALANCE for your remaining credit and allowances
HELP TOP UP to find out how to top up via text
BOOST to check the status of your free BOOST
ALL PACKS for a list of packs available
HELP PAYG for a link to online help
STOP PACK to stop any active packs from recurring
RO country name for roaming rates
STOP to 1234: to opt out of marketing communications
Thus it seems that you cannot send ROAMING to 150. Therefore how should I check/set up my phone for roaming please?
Re: Sending ROAMING to 150 does not work
@drinu8  Try calling customer services and asking if the text message is not working.
