by Chaz2
Sendin a text from abroad do I need to put roaming to 'on' in my phone settings?
I am going abroad this weekend, I have text 150 and it has confirmed my roaming is active. When I go away do I change my roaming settings to 'roaming' in my phone settings to be able to send a text? I dont want to use data abroad I only want to send texts. If roaming is on will I incur data charges even if I do not use the internet?
by Profile closed
Not applicable
Re: Sendin a text from abroad do I need to put roaming to 'on' in my phone setti
Hello @Chaz2 for T-Mobile & Orange you may be charged for having data roaming active yes but not EE as the system does not let your device access data services unless you have purchased a data roaming add on. As long as roaming is active you should be able to call & text (also chargeable) but you may need to switch off call barring if you have an Android device. :):
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-using-your-phone-abroad
by Chaz2
Thats brilliant!! Thank you so much for your help!! 😊
by Profile closed
Not applicable
You are welcome @Chaz2 come back to the community anytime if there is anything else you would like to know. 🙂
Put Roaming (in general) ON if there is a setting for it but keep Data Roaming OFF.
