Highlighted
by Established Contributor
Select specific roam network
I am planning to travel to Greece for two months. I will be in a village that I know that only Cosmote has an acceptable signal.
So my questions are:
  1. How can I force the selection to a specific network during roaming?
  2. How can I check if Cosmote is in the roaming partners of EE? The same question applies also for other countries. How I can find roaming partners in countries that I am travelling. In the past most network providers they had a drop-down list but not anymore.
In my last travel (three months ago) to Greece, I noticed that I wasn't able to manually roam to Cosmote network. That wasn't the case a year ago.
Highlighted
by Ace Contributor
Solution
Re: Select specific roam network
Hi @ioannisa
Q1: This depends what phone you're using, but generally - go into your network settings, and there will be an option for "manual selection" or maybe "search for networks", or "automatic selection".
Q2: It's a bit old, but this lists all of EE's 4G roaming partners, as far as I know there isn't a published list of all the available networks globally.
Highlighted
by Ace Contributor
Solution
Hi @ioannisa
Highlighted
thanks a lot. It would have been great if EE was publishing and keep updated a roaming partners list.
I am pretty sure that last time I tried to force the manual selection to Cosmote for Greece and the phone wasn't registering with the network so I switched back to automatic.
Recent solutions
