by andywalker83
SMART Plan with Roam Further and Sharer sim
Hi, I am currently on an EE Max 100GB and a Sharer Sim for the wife. When we go the US my wife can use my data but no calls and text. Will this be the same if I upgrade to the new sim only SMART 100GB Plan with Roam Further?
Re: SMART Plan with Roam Further and Sharer sim
@andywalker83   You’ll need to enable call abroad and premium rate numbers on the account for it to work while in the US.
Hi @andywalker83
Welcome to the community. 🙂
It should work the same. I recommend speaking to our upgrades team when you come to upgrade. They'll be able to check your account confirm compatibility with the shared plan you have and the new Smart plans.
They'll look into all of your other options too, in case there's a better way of setting your account up.
